Omnicore GS/AS configuration
I have the new V250XT Omnicore controller and there are many changes compared to the old IRC5 controller.
I read in the manual that you can configure the GS input for the AS, but I can't find where to do it in robotstudio:
Safeguard mechanisms
• Protective stop through
- Three-position enabling device (release of or compression past the
center-enabled position)
- General Stop, GS (see actual configuration, can be configured to either
AS or GS)
Any suggestion?
Thanks in advance
AS or GS)
Any suggestion?
Thanks in advance
Its in the safety configuration - go to controller then safety in robotstudio1
