IRB 14050 and "Arm-Angle Reference Direction" setting
I've been told that I should set Arm-Angle Reference Direction to Axis 1 in the controller configuration when using the YuMi Single Arm Robot. I've got a few questions:
- if that is important (avoid singularities, etc.) why it is not the default when adding a controller From Layout?
- how is that setting manged when programming online with the Flexpendant only?
- where is such option (and its recommended value) documented? I couldn't find it on the robot Product Manual or RobotStudio Operating Manual.
Thanks!
Nobody answered, the answer is here https://library.abb.com/d/3HAC065041-001
