What is the limiting factors in the speed of running a simulation
Does RobotStudio Desktop have any hardware/performance limitations.  I want to throw a lot of CPU cores etc at it, but it doesn't seem to have the desired result.  Is there a CPU / Core count limitation, or any other factors at play which wont let the Simulation run as fast as possible with all resources?  I get a simulation running and it will just sit at 30% CPU usage.
What is the recommended system for the software  Other than Windows 10 and >2.0GHz CPU there is very little info I can find.
PS I am not a user of the software, but provide the system for it to run on.
  • lemster68
    lemster68 ✭✭✭
    The graphics card that you use is what will make it go faster, perform better. You will also need to ensure that the system is set up to run RS using that graphics card rather than built-in on motherboard, if applicable.
    Lee Justice
