How to set the SafeZone UCS in the controller?
As shown in the linked image, I can set the SafeZone relative to the UCS, but how to define the UCS in the controller? Is there any other way to define the safeZone relative to a Workobject?
No you cannot. For it to be safety rated, it cannot rely on a work object value. If you are tying to do something that does not need to be truly safety rated, you can switch over to world zones.
Sorry for the bad news.0
