2 robots mounted on a single track in robot studio.
Design
I am trying to create a station in which 2 robots are mounted on a single irbt 2005 track. Firstly I am not able to import this track with 2 robot carriages as shown in the product intro pdf of IRBT 2005 track. So, I created my own mechanism with 2 linear moving plates and added two IRB 2600 ID robots on it. But I am not able to create virtual controller for this station. So, I request some one to guide me as to how to create a station where I can mount 2 IRB 2600 ID robots on a single linear track. Robots are going to work in multimove independent.
Thanks for time and help.
https://youtu.be/pJeok4rkrns?si=_O6wlIDginWB6aX_
The above video should show what I believe you are wanting to do or at least get you on the right track. Not I am using robotware 6.15.06. I have not had a chance to verify that multimove is available in omnicore robots yet. All of the robotware 6.xx options should work though.2 -
Thanks sir. You created the video just to solve my problem. Thanks for this kind of support. Thanks kind sir.revans said:https://youtu.be/pJeok4rkrns?si=_O6wlIDginWB6aX_
The above video should show what I believe you are wanting to do or at least get you on the right track. Not I am using robotware 6.15.06. I have not had a chance to verify that multimove is available in omnicore robots yet. All of the robotware 6.xx options should work though.0
