Event Message 40728
Trying to Modify Bullseye on a 180 neck.  Receiving Event Message 40728.  Unable to calculate new frame.  Any suggestions?
  • Had to do TCP manually.  Could not get 180 torch to pass Bullseye.
  • Was this on the setup run?
    How far through did it get before the 40728 error?
  • It would find the beam, rough check, tool straightening.  But during the intermediate TCP it would throw that error.
  • Are you at or near singularity?
    Lee Justice
  • No.  It is a 180 short torch.  5 is basically at a 90 degree angle in relation to 4, in order to get the torch perpendicular to the atbeam point.  Not even close to singularity.
  • Found a couple of support cases on this error:
    1. The tcp is not allowed to be in line with axis 6. In your case Z axis would not be but Y or X could
      Can you add an adapter flange to create a slight angle?
    2. Try using AccSet 30,30 to slow down the acceleration.
  • We would have to add an adapter flange.  We have a 180 torch on an ATI, and that one runs fine.  We ended up switching the 180 to a 22, so it is no longer an issue having to try and modify the bullseye.  Thanks.
