IRC 5 FTP Server
We just received our first ABB robot with the IRC 5 controller.
On our older S4C controllers I had them all on the Lan and used an FTP client to upload program changes, download backups, etc.
I have placed the controller on the network and attempted to connect using my ftp client. I can't find anywhere in the documentation what the ftp username/password is. When I attempt to connect I get the error "530 Login Failed." and can't connect.
Could anyone tell me what the login info is?
You can use any non-blank user name and password.Russell Drown0
Yeah, thats what I thought as well, since that is how all of the older S4C controllers are set up.
When I attempt to connect to the IRC5 however, I get the login failed.
Here is what I see in my ftp client when I try a non blank user name and pwd. In this case abb and abb.
Status: Connecting to 10.110.9.34 ...
Status: Connected with 10.110.9.34. Waiting for welcome message...
Response: 220 ABB Robotics FTP server (VxWorks5.5.1) ready.
Command: USER abb
Response: 331 Password required
Command: PASS ***
Response: 530 Login failed.0 -
If you don't have the option "pc interface 616-1" you can only use the service connection.
Have you tryed the ftp in Robotstudio online on the service connection ?
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
That I have not. After reading some of the other posts I was feeling sort of sheepish, thinking that I better try the service port.
I will give it a shot and let you know what happened.
I have a feeling I am going to need to get that option installed. I like the functionality, and use it quite a bit. I wonder how much that little sucker is?
Okay, I have figured it out.
We had configured the UAS to provide different levels of access. I logged in to the FTP site using the credentials I gave to an administrator type account and away I went.
Now I have the functionality that I had been missing most.
I have looked, and I do not have the PC-interface option 616-1 and can still connect. Robot Studio Online does tell me it can't connect when I try over the network because of the missing option. But as long as I have FTP I'll be happy.
Thanks for the update.Russell Drown0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
