Search for multiple inputs
laov
I need to preform a linear search untill 1 of 5 inputs triggers from 1 to 0. SearchL command only accepts 1 input. Any way to combine inputs? Or search for multiple inputs / GI?
The only other ideas I have is to move in a while cycle or stop the movement via Interrupt.
All help and suggestions welcome...
Best Answers
Make a simulated input to which you cross connect those five other real inputs using the OR operator. Use that simulated signal in your search.Lee Justice0
Create another signal and use it as a result in a Cross Connection with the other 5 as Or conditions, then use the new signal in your SearchL0
Found it.
Configuration -> I/O system -> Cross Connection.
Thanks!0
lemster68 said:Make a simulated input to which you cross connect those five other real inputs using the OR operator. Use that simulated signal in your search.0
That is because you need to read the System Parameter manual for cross connections. No code is required.Lee Justice0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
