Unable to use Backup and pack&Go
i am unable to do backup and use pack&Go
every time i use this f**ktion a message appears telling me that VC has encountert a problem an need to be close.
the controller works fine both in RS and AWPP
i have just upgradet to 5.08 for both RS and AWPP
i had same problem with 5.07
HELP is needet
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
  • SORRY FOR THE MISTAKE IN "FUNCKTION":)
    Kent Zibrandtsen
  • Is this when you run the Pack & Go wizard, or when you open the station on a different computer?
    Johannes Weiman
    ABB Robotics
  • Klaus
    Klaus ✭✭
    Hei kent.
    I have tried it and it works for me. I use the same options as you.
    Best regards klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • It chrashes when I use the funktion on my computer
    Kent Zibrandtsen
  • It happens both if i use pack and go, but also if i try to backup with flexpendant. every time i try the controller crashes.
    Kent Zibrandtsen
  • That sounds strange. Which RobotWare version is the controller using?
    Johannes Weiman
    ABB Robotics
  • im am using Robotware version 5.07.1030.01
    Kent Zibrandtsen
  • No matter which options i chose in the pack and go wizard, i always seem to get the systems and backups included the zip file.  Has anyone else found this?
    Regards
    Craig Pentecost
  • Hi Craig,
    Systems are always included, there is no option to disable that.
    If you uncheck backups new backups shouldn't be created, however existing backups in the system (the BACKUP subfolder) will still be included.
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
