RobotStudio Connection Via IO Network
I cannot connect to the robot via the io network, only the management port. I can ping the robot fine, and all the firewall settings are set to allow for the IO network.
Is this possible?
  • If you do not have the PC Interface option it is only possible to connect to the robot via the management (service) port. Do you have this option?
