write and use a csv. file with my robot
Hello! I am trying to measure the force generated by my robot and write it to a CSV file. What I need is for the force measured by the sensor to be written to the document so that I can access it later. How does the
Open() function work? What is the difference between "HOME:" and "PC:"? I would be very happy if someone could provide me with an example of how to write information to a document and then access it from my computer. Thank you! 0
Here is another example:MODULE OffsetLog!*****************************************************! * Copyright (C) 2019 Lee Justice! *! * Licensed under the Apache License, Version 2.0 (the "License");! * you may not use this file except in compliance with the License.! * You may obtain a copy of the License at! *! *! * Unless required by applicable law or agreed to in writing, software! * distributed under the License is distributed on an "AS IS" BASIS,! * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.! * See the License for the specific language governing permissions and! * limitations under the License.!*****************************************************!*****************************************************! Module Name: OffsetLog! Version: 1.0! Description: ! This module shows how to make a text file for logging! data. A lot of people like to make a .csv file to! open with excel. I prefer the readability of a text! file. With some adaptation, you could change it to! write a .csv file! Date: 2019-10-18! Author: Lee Justice!*****************************************************! Data logging module to record trueview offsets! provided to R62 for roof load onto car.!! Boolean bQuiet is switch to turn on or off! TPWrites as desired.!! Boolean bLogData is switch to turn on or off! the data logging altogether.!! Numeric nFreeFlashPer is the percent value! of flash drive free space below which the! program will erase the log file and begin a new! file, so the flash drive will not fill up.! Adjust as desired.!! Created: 10-09-2011!PERS string ActiveStylString;PERS num nXoffset;PERS num nYoffset;PERS num nFreeFlashPer:=32;PERS bool ComDevIsOpen:=FALSE;PERS bool bQuiet:=FALSE;PERS bool bLogData:=FALSE;PROC rLogOffsets()VAR iodev datalog;VAR string stDate;VAR string stTime;VAR num nFreespace;VAR num nTotalspace;IF bLogData THENstDate:=CDate();stTime:=CTime();nFreespace:=FSSize("HOME:/Offsets.txt"\Free);nTotalspace:=FSSize("HOME:/Offsets.txt"\Total);IF ((nTotalspace-nFreespace)/nTotalspace)*100<nFreeFlashPer THENIF ComDevIsOpen Close datalog;Open "HOME:"\File:="Offsets.txt",datalog\Write;ComDevIsOpen:=TRUE;Write datalog,stDate+", "+stTime+", "+"New offset data log created.";ErrWrite\W,"File removed","Removing Offsets.txt from the HOME directory."\RL2:="To keep flash drive from filling.";ELSEIF ComDevIsOpen Close datalog;Open "HOME:"\File:="Offsets.txt",datalog\Append;ComDevIsOpen:=TRUE;Write datalog,stDate + ", " + stTime + ", " + ActiveStylString + ", " + " nXoffset is: "\Num:=nXoffset\NoNewLine;Write datalog,", nYoffset is: "\Num:=nYoffset;Close datalog;ComDevIsOpen:=FALSE;IF bQuiet THEN! Do nothing, only silence TPWritesELSETPWrite "The file containing the offset data is in the HOME directory.";TPWrite "Use the File Manager to retrieve a copyof Offsets.txt.";ENDIFENDIFENDIFRETURN;ERRORTEST ERRNOCASE ERR_FILEACC:IF ComDevIsOpen Close datalog;Open "HOME:"\File:="Offsets.txt",datalog\Write;Write datalog,stDate+", "+stTime+", "+"New offset data log created.";Close datalog;RETRY;DEFAULT:Stop;! An unanticipated error has occurred! see system variable ERRNO for cause.ENDTESTENDPROCENDMODULELee Justice0
