Trap conditions
How to activate the trap conditions in robot running time DO signal cutoff means how to stop the robot
  • A little more explanation would be appreciated but here is an example of what I think you are referring to.
    VAR intnum sig1int;
    PROC main ()
    IDelete sig1int;
    CONNECT sig1int WITH trap_stop_at_once;
    ISignalDO do1, 0, sig1int;
    !Do stuff here.
    !Do stuff here
    TRAP trap_stop_at_once
    stop;
    ENDTRAP
    VAR intnum sig1int;
    PROC main ()
    IDelete sig1int;
    !Do stuff here.
    !Do stuff here
    stop;
    ENDTRAP
    Hi ...
    Use ISleep and IWatch to start and stop trap monitoring.
    Just Complementing...
        ISleep sig1int ! Avoids recursion while executing the trap
        StopMove;
        ! Wait for UP Signal
        WaitUntil do1=1;
        StartMove;
        IWatch sig1int
    ENDTRAP
    Good Job
