First cycle flag in Rapid
Did you ever find anything to do with first cycle? I have a few things I need to do in first cycle only too.0
Try an event routine for Power On to run a one instruction routine that sets a PERS boolean, e.g. bFirstCycleOnly, variable TRUE.
PROC rPowerON
bFirstCycleOnly: =TRUE;
Be sure to change state of the PERS to FALSE in your production code.
As an idea in production code
PROC rFirstCycle()
IF bFirstCycleOnly THEN
Stuff
bFirstCycleOnly: =FALSE ;
ELSE
Return;
ENDIF
1
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
