Where is MatrixAdd?
Slokko
Hello. I'm trying to cleanup some code and realized i could save a lot of rows by useing MatrixAdd and MatrixReset. "They are in the RAPID Instructions, Functions and Data types for RobotWare 7.15"
But when I try to implement them I get no IntelliSense and Rapid says "Identifier not found"
The code I want to input:
MatrixAdd SavedPositions, PosAdjust, SavedPositions;
MatrixReset PosAdjust;
What gives?
What gives?
Post edited by Slokko on
MatrixAdd is used to add one matrix to another matrix. A matrix can only be added to another matrix if the two matrices have the same dimensions, and the result will be a matrix with same dimensions as A.
lets see your matrix declarations0 -
I think you also have to use dnum data type and the result needs to be a VAR
1 -
Hello.
It's not a syntax issue. It was omnicore. Or RobotWare to be exact. A lot of the Matrix-instructions seems to be missing in RW 7.8.2.
In RW 7.15.2 (and quite possibly earlier) they are back. Problem "solved".
Hello,MatrixAdd was introduce from RW 7.14 (in ReleaseNotes)They should notify this in Help.☑️2024 - RobotStudio® User Group0
Ah yes..i had to update to use matrixmult0
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
