How to load . mod program from hd02 to working memory and execute .
Hello all
I create  small application for the  ABB robot  create FTP for sending the mod files
But  now  I have problem with  execution of  program .
What kind of script  I need  in main prog  to load the program from  hd02  execute it
and after unload and load next ?   PLC  is sending the  info  which   .mod  to start .
Connect  to IRC5  is working  send  the  PROG_*.mod  working .
  • DenisFR
    DenisFR ✭✭✭
    Answer ✓
    You can use Load or StartLoad instruction then call your routine with late binding (%).
    Look at RAPID Instruction, Functions and Data types help file for examples.
