Is it possible to custome service routines?
Not sure if this is the right section but I could not find a FlexPendant topic so here goes:
Is it possible to create a sub category of my own in flexpendant debug, call routine section? Or add my own routine into service routines? I would like to define some maintenance routines - moving robot to a certain maintenance possition and returning from it reliably for the average operator.
  • DenisFR
    DenisFR ✭✭✭
    Answer ✓
    You can add it in MMC.cfg file in MMC_SERV_ROUT_STRUCT: section
  • DenisFR said:
    Thank you this worked. I now see all my procedures along with service routines. This is much better then before but to be ideal I'd like to define a custom category so that flexpendant would show:
    All Routines
    My Routines
    Service Routines
    Is this possible?
