Is it possible to custome service routines?
laov
Not sure if this is the right section but I could not find a FlexPendant topic so here goes:
Is it possible to create a sub category of my own in flexpendant debug, call routine section? Or add my own routine into service routines? I would like to define some maintenance routines - moving robot to a certain maintenance possition and returning from it reliably for the average operator.
Hello,You can add it in MMC.cfg file in MMC_SERV_ROUT_STRUCT: section
☑️2024 - RobotStudio® User Group0
Thank you this worked. I now see all my procedures along with service routines. This is much better then before but to be ideal I'd like to define a custom category so that flexpendant would show:DenisFR said:Hello,You can add it in MMC.cfg file in MMC_SERV_ROUT_STRUCT: section
All Routines
My Routines
Service Routines
Is this possible?0
- 367 IRC5
- 858 RAPID Programming
