How to edit mechanism axis after creation
Daper
How can I change the rotation/translation axis of a mechanism after it has been created ?
In my case, I need to raise up a linear axis of a gantry system that holds a robot by 100 mm but I want to avoid rebuilding the mechanism from start.
And ideally if possible, I would like to shift all the associated targets of my path by 100 mm as well.
Can I do this ?
Can I do this ?
Best Answers
You should be able to modify it.
Make sure it is not connected to a library (rslib), or disconnect it.
Make sure to detach any object attached to the mechanism (e.g is the robot mounted on the gantry ?)
Also if it was built with e.g an older RS version it might block for modification.
Anyway if you just need to raise the mechanism by 100mm : it is much simpler to move the current gantry and update the calibration or baseframe.
Thank you a lot !0
- 345 IRC5
- 71 OmniCore
- 843 RAPID Programming
- 19 AppStudio
