[Wish] Synchronize path to station
When I right-click a path, I get the option to "Synchronize to RAPID...".
I would like the option to Synchronize to Station and get the path pre-selected in the popup dialog.
If I helped, please press Vote Up  :smile:
  • Hi...
    I don't know if this option exists! Why would it be necessary?
    In the Simulation tab, when you create a path using the drawing tools  don't have the Synchronize To RAPID option, this is missing. Therefore, this option is a way to synchronize without having to navigate between tabs. However, if you created a path using RAPID, you can synchronize it using the Synchronize To Station shortcut on the toolbar.
  • Well I got a system with over 100 procs, but only 10 contains movements.
    So I want to write rapid (change offsets and so on..) and then update the station with the new values.
    But I don't want to search for the proc in a list with over 100 procs when I know I only want to sync one path.
    So it would be perfect to have the same function as Synchronize to RAPID... but reversed.
  • Second this. Either that, or have the path list filterable by module?
  • bump
  • Something like this would be useful for me to.
    My personal preference is to always "clean up" my station after syncing the proc back to Rapid, and I usually only work with one proc at a time.
    I delete the path and right click on T_ROB1 and select "Remove unused targets". Then I delete the work objects.
    For me a function to "Remove all targets, tools, wobjs and paths" would also be useful.
    David
    Swedish freelance ABB robot programmer
