controlling irc5 with Python using EGM (robotstate 1.1)
Hello everyone,
as written in the topic, I'm trying to send EGM_START_POSE a value to move my end effector to a spacific position and orientation.
I downloaded the state machine add in which providing TRobEGM module:
       Provides support of using the following Externally Guided Motion (EGM) features:
       - EGM UDP unicast variant (i.e. type of communication), with the following modes:
         - EGM joint mode (for controlling motion).
         - EGM pose mode (for controlling motion).
         - EGM stream mode (for streaming position data).
 I run this program i wrote to initialize the procedure:
MODULE MainModule
    PROC main()
        initializeEGMModule;  ! Initialize the EGM module
        WHILE TRUE DO
            runEGMRoutine;  ! Run the EGM routine to handle external commands
        ENDWHILE
ENDMODULE
I have connected the robot to my pc by ethernet cable and after sending command via RWS (like turnning the motors on/off and running basic rapid program) i decided to control it from Python.
this is the script:
import socket
import struct
import time
import math
def main():
    robot_ip = "192.168.125.1"  # Robot controller IP
    port = 6511  # Port for ROB_1 (EGM Pose Mode)
    udp_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    sequence_id = 1  # Initialize Sequence ID
    # Example Cartesian pose: X (mm), Y (mm), Z (mm), Rx (rad), Ry (rad), Rz (rad)
    position = [300.0, 200.0, 400.0]  # Position (X, Y, Z) in mm
    orientation = [0.0, math.radians(30), math.radians(45)]  # Orientation in radians
    try:
        while True:
            timestamp = time.time()
            # Pack header: Sequence ID (uint32) and timestamp (double)
            header = struct.pack('>I d', sequence_id, timestamp)
            # Pack pose data: X, Y, Z, Rx, Ry, Rz (6 doubles)
            pose_data = struct.pack('>6d', *(position + orientation))
            # Combine header and pose data
            message = header + pose_data
            # Send the UDP packet
            udp_socket.sendto(message, (robot_ip, port))
            print(f"Sent pose: {position + orientation} | Seq ID: {sequence_id}")
            sequence_id = (sequence_id + 1) % (2**32)  # Wrap sequence ID
            time.sleep(0.004)  # Send at 250Hz (4ms)
    except KeyboardInterrupt:
        print("Streaming stopped.")
    finally:
        udp_socket.close()
if __name__ == "__main__":
    main()
After Establishing RWS connection and turning the motors on, I run the rapid program which waits for position and orientation so I run the Python scrupt but the robot stands still. I alreday configured the IP Adresses and Remote Port Numbers.
Can someone tell what am I missing?
Thank for the help!
  • I'm not too familiar with the EGM system, but my first thought is that in most cases ABB robots use quaternions for orientation, not XYZ euler angles. It's worth double checking, at least, if that's the orientation format it's expecting.
