Socket communication error
Claudiu_Muresan
edited January 2025 in IRC5
Hello everybody,
I'm currently trying to estabish a socket communcation between an ABB IRB1200 Robot and a 3D Camera from Solomon. The controller has the PC-Interface package installed, the robot IP is 192.168.0.6 and the PC has the IP 192.168.0.2 and the declared port 10000. I can succesfully create the Socket but when it reaches the SocketConnect command it idles there until the timeout error occures. I was wondering if you have any ideas for this problem. Thank you very much!
!Creating socket and verifying
      SocketCreate SocketSolomon;
      IF (SocketGetStatus(SocketSolomon)=SOCKET_CLOSED) THEN
          TPWrite "Socket failed to create!";
          SocketFails:=SocketFails+1;
          GOTO VisionInit;
      ELSE
          TPWrite "Socket created successfully!";
      ENDIF
      !Connecting socket and verifying
      SocketConnect SocketSolomon,"192.168.0.2",10000;
      IF (SocketGetStatus(SocketSolomon)<>SOCKET_CONNECTED) THEN
          TPWrite "Failed to Connect!";
          SocketClose SocketSolomon;
          GOTO VisionInit;
      ELSE
        TPWrite "Socket connected successfully!";
      ENDIF
Post edited by Claudiu_Muresan on
  • Hi ...
    There is a time for creation, connection and data exchange, in addition there is a number of sockets and connections that are allowed, so try not to create/connect too many sockets.
    I believe you are not giving enough time for the commands to complete.
    Try the solution to see what appears as a response.
    PROC ConnectServerSocket(string addressP,num portP)
            ! ## ATTRIBUTES ############################################# ##############################
            VAR socketdev mySocketL;
            ! Creates a connection via socket if there is no connection created with the PLC for data exchange ...
            IF SocketGetStatus(mySocketL)<>SOCKET_CREATED THEN
                SocketCreate mySocketL;
            ENDIF
            IF SocketGetStatus(mySocketL)=SOCKET_CREATED THEN
                SocketConnect mySocketL,addressP,portP\Time:=1;
                IF SocketGetStatus(mySocketL)=SOCKET_CONNECTED THEN
                    ! CODE ....
                ENDIF
            ENDIF
            ! At the end of the routine, close the connection with the PLC to avoid creating an unnecessary socket when executing the routine again ...
            SocketClose mySocketL;
            RETURN ;
        ERROR
            ! #################### Handling error ################### !
            TEST ERRNO
            CASE ERR_SOCK_TIMEOUT:
                ErrWrite "ERR_SOCK_TIMEOUT","";
            CASE ERR_SOCK_CLOSED:
                ErrWrite "ERR_SOCK_CLOSED","";
            DEFAULT:
                TPWrite "??? ERRNO ???";
            ENDTEST
            ! Testando o status do socket para definir ações a serem tomadas ...
            TEST SocketGetStatus(mySocketL)
            CASE SOCKET_CREATED:
                TPWrite "SocketCreate";
            CASE SOCKET_CLOSED:
                TPWrite "SocketClose";
            CASE SOCKET_BOUND:
                TPWrite "SocketBind";
            CASE SOCKET_LISTENING:
                TPWrite "Instruction SocketListen or SocketAccept has been executed";
            CASE SOCKET_CONNECTED:
                TPWrite "SocketConnect, SocketReceive or SocketSend";
            DEFAULT:
                TPWrite "??? SocketGetStatus ???";
            ENDTEST
            RETURN ;
    Good Job.
