IO-Link setup
Tompanhuhu
Hi!
I have connected a few IO-Link devices to ABB Robots and always had to map the signals manually from the products documentation.
Has anyone managed to make a iolist from a iodd file with all signals and correct mapping?
☑️2024 - RobotStudio® User Group
Sorry for wakening up an old thread, but this is exactly what I am struggling with right now.
We have an Balluff ProfiNet node (BNI PNT 508 105 z015) on the robot and now we want to add an IO-Link proportional valve (VP5006BJ511H00) to port 6 and control the pressure to the gripper depending on product type.
The node itself is already configured, we use some ports as Input and Output already.
But how do I map the proportional valve signals in robot according to the IODD file?
Can you help me get starting as all I tried has not worked so far.
Link to IODD page: IODDfinder
It would be very user friendly if you could use the IODD file directly in I/O-Engineering tool to add IO-Link units.Post edited by Tedenljung on0 -
@Tompanhuhu
Can you tell how you did setup IO-Link devices manually?0 -
Sorry I don't have any experience with Balluff IO-Link master.
But you can map your device-io with the information found here:
https://ioddfinder.io-link.com/productvariants/search/30881
Go to IODDviewer and then Process data.
You can see that your device use 8 input bytes and 4 output bytes in the robot.
first 32 input bits are device temperature
last 32 input bits are device output pressure
demand pressure is set with first 32 outputs.
Create analog signal or group signal and mapp them with correct offset to your master.
Sorry I can't be of more help.Systemintegrator - Web / C# / Rapid / Robotstudio
Has anyone managed to make an IO list from an IODD file with all signals and correct mapping?
I am currently using a Schmalz SCTSi IOL 4 as an IO Link device and connected to an IFM AL1420 IO Link Master with EtherNet/IP interface. I am connected via ethernet to an IRC5 controller. I have the IODD files from the Schmalz unit and the EDS file from the IO Link Master0
- 344 IRC5
- 71 OmniCore
- 843 RAPID Programming
- 19 AppStudio
