How do I configure my own alarm on the Flex Pendant?
in IRC5
Dear Experts,
I have an additional digital input connected to the controller I/O system to check whether the mixing unit, where the robot is placing samples, is ready or not. I would like to display an alarm on the Flex Pendant when the mixing unit becomes not ready and also understand how to use this alarm in ABB RAPID/configuration to set the ABB robot to "not ready" as well. Thanks.
Ahmed
Ahmed
Read up on the ErrRaise and ErrWrite instructions in the technical manual - Instructions, Functions and Datatypes.Lee Justice0
Hi Lee,
Thank you for your reply. I will check and try.0 -
Hi Lee,I have tried but it isn’t working. Please guide me if I am doing something wrong.
I have added this to RAPID:
PROC mixing_alarm()
IF DInput (mixing_ready)=1 THEN
ErrWrite\W, "Mixing unit not ready","";
ENDIF
best regards,
Ahmed0 -
How do you have it set up to execute your proc? The robot needs to execute the code somehow0
Hello
You can configure a custom alarm on the Flex Pendant using RAPID.
- Monitor the Digital Input: Use a trap routine or cyclic task to check the mixing unit status.
- Trigger an Alarm: If the unit is not ready, use SetAlarm to display a message and stop the robot:
VAR alarmid myAlarm;
PROC check_mixing_unit()
IF DI_MixingUnit_NotReady = 1 THEN
SetAlarm myAlarm, "Mixing unit not ready!", 1;
StopMove;
ENDIF
Set Robot to "Not Ready": Modify SysPar or use logic to prevent movement when the alarm is active.
Thank you.
- 858 RAPID Programming
