How do I configure my own alarm on the Flex Pendant?
Dear Experts,
I have an additional digital input connected to the controller I/O system to check whether the mixing unit, where the robot is placing samples, is ready or not. I would like to display an alarm on the Flex Pendant when the mixing unit becomes not ready and also understand how to use this alarm in ABB RAPID/configuration to set the ABB robot to "not ready" as well. Thanks.
Ahmed
  • Read up on the ErrRaise and ErrWrite instructions in the technical manual - Instructions, Functions and Datatypes.
    Lee Justice
  • Hi Lee,
    Thank you for your reply. I will check and try.
  • imnisarahmed
    edited February 2025
    Hi Lee,
    I have tried but it isn’t working. Please guide me if I am doing something wrong.
    I have added this to RAPID:
    PROC mixing_alarm()
    IF DInput (mixing_ready)=1 THEN
    ErrWrite\W, "Mixing unit not ready","";
    ENDIF
    best regards,
    Ahmed
  • jarmster
    jarmster
    How do you have it set up to execute your proc? The robot needs to execute the code somehow
  • Hello
    You can configure a custom alarm on the Flex Pendant using RAPID.
    1. Monitor the Digital Input: Use a trap routine or cyclic task to check the mixing unit status.
    2. Trigger an Alarm: If the unit is not ready, use SetAlarm to display a message and stop the robot:
     VAR alarmid myAlarm;
    PROC check_mixing_unit()
        IF DI_MixingUnit_NotReady = 1 THEN
            SetAlarm myAlarm, "Mixing unit not ready!", 1;
            StopMove;
        ENDIF
    Set Robot to "Not Ready": Modify SysPar or use logic to prevent movement when the alarm is active.
  • Thank you.
