Is RobotStudio license still valid after WINDOWS upgrade?
KennyJiang
mod
Is RobotStudio license still valid after a system upgrade for WINDOWS? Or does a new license need to be purchased and activated?
Hello!
Upgrading windows should not invalidate your license.
If it does, please send an email to softwarefactory_support@se.abb.com and ask for support.
Thanks!—Maxim RiabichevPC Software Support Engineer0
Hi ...Once a bug caused problems with Windows updates, and it was necessary to run an ABB package to solve the problem - in this case it took about three days to solve.The license takes into account the machine where RS was installed. What can cause inconvenience is if the RS version requires a specific OS or a bug in RS. In this case, report it to ABB support.I hope this helps.Good work.0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
