downgrade after upgrade robotware
Did you install the system into the contoller?Lee Justice0
I did: In Robotstudio/Installation/Modify Installation -> Updatethe controller then updated itself to RW7.16The problem is that the IO configurator is now crying that it can't handle RW7.16 and there doesn't seem to be a version of the IO configurator that fits RS7.16I expected there to be a way back but it doesn't seem to be possible!?Daniel
Cold start the controller. Delete that system in Robotstudio and make another with 7.15.Lee Justice0
I used RS2024.3 yesterday, but this version cannot handle Robotware 7.16.With RS2025.1 it is possible: to go back to an older version under: Robotstudio/Installation/Modify Installation -> Update (here now is selection possible)The option to create a new system or a system from a backup as in RW5 and RW6 does not seem to be possible in RW7 or RS2025.1 until now.Daniel
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
