Impossible to connect and deploy to my Virtual controller
Luxrobotic
in AppStudio
Hi everybody,
I'm starting with Appstudio.
I did a small project and want to deploy it, but I can't connect to my virtual controller.
I've seen that the "World Wide Web Publishing Service" should be activated, but I don't find it in my services list.
I also tried without any firewall active.
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
World Wide Web publishing service must NOT be activated, nor any other application or service that uses port 80.
1 -
You can also refer to this post: https://forums.robotstudio.com/discussion/14545/how-to-connect-to-the-virtual-controlle for your question.0
