Has anyone managed to make an IO list from an IODD file with all signals and correct mapping?
I am currently using a Schmalz SCTSi IOL 4 as an IO Link device and connected to an IFM AL1420 IO Link Master with EtherNet/IP interface. I am connected via ethernet to an IRC5 controller. I have the IODD files from the Schmalz unit and the EDS file from the IO Link Master
I have made my own script to convert IODD to ABB io-list.
This is the output i got from the iodd file, you can test if it works.
I entered starting bit 0 so if your signals start at 8 or 16 you have to add that value to the bit values.Enter the path to the IODD file: ****\Schmalz-SCTSi-IOL_4-20211028-IODD1.1.xml Enter the ABB start bit offset INPUT: 0 Enter the ABB start bit offset OUTPUT: 0 Robot inputs: Description : Address Number of device which generated a condition monitoring or error event: 3-7 EPC Select Acknowledged: 5 Device Status: 6 EPC Value 1: 8-15 EPC Value 2 High: 16-23 EPC Value 2 Low: 24-31 Air Saving Function (H1) Ejector 1: 32 Part Present (H2) Ejector 1: 33 Air Saving Function (H1) Ejector 2: 34 Part Present (H2) Ejector 2: 35 Air Saving Function (H1) Ejector 3: 36 Part Present (H2) Ejector 3: 37 Air Saving Function (H1) Ejector 4: 38 Part Present (H2) Ejector 4: 39 ******************** ABB CONFIG STRING ******************** -Name "Number of device which generated a condition monitoring or error event" -SignalType "GI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "3-7" -Name "EPC Select Acknowledged" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "5" -Name "Device Status" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "6" -Name "EPC Value 1" -SignalType "GI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "8-15" -Name "EPC Value 2 High" -SignalType "GI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "16-23" -Name "EPC Value 2 Low" -SignalType "GI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "24-31" -Name "Air Saving Function (H1) Ejector 1" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "32" -Name "Part Present (H2) Ejector 1" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "33" -Name "Air Saving Function (H1) Ejector 2" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "34" -Name "Part Present (H2) Ejector 2" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "35" -Name "Air Saving Function (H1) Ejector 3" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "36" -Name "Part Present (H2) Ejector 3" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "37" -Name "Air Saving Function (H1) Ejector 4" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "38" -Name "Part Present (H2) Ejector 4" -SignalType "DI" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "39" Robot outputs: Description : Address Number of device which will send EPC Data: 0 EPC Select 0: 6 EPC Select 1: 7 Input Pressure: 8-15 Vacuum Ejector 1: 16 Blow Off Ejector 1: 17 Vacuum Ejector 2: 18 Blow Off Ejector 2: 19 Vacuum Ejector 3: 20 Blow Off Ejector 3: 21 Vacuum Ejector 4: 22 Blow Off Ejector 4: 23 ******************** ABB CONFIG STRING ******************** -Name "Number of device which will send EPC Data" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "0 -Name "EPC Select 0" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "6 -Name "EPC Select 1" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "7 -Name "Input Pressure" -SignalType "GO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "8-15 -Name "Vacuum Ejector 1" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "16 -Name "Blow Off Ejector 1" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "17 -Name "Vacuum Ejector 2" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "18 -Name "Blow Off Ejector 2" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "19 -Name "Vacuum Ejector 3" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "20 -Name "Blow Off Ejector 3" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "21 -Name "Vacuum Ejector 4" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "22 -Name "Blow Off Ejector 4" -SignalType "DO" -Device "REPLACE_IO_DEVICE"\ -Access "All" -DeviceMap "23 Press any key to continue...
☑️2024 - RobotStudio® User Group0
- 367 IRC5
- 858 RAPID Programming
