Help Loading an Pack an Go File
Hello Team I got an Pack and go File from an Client my older Robot Studio couldnt open it.
So I installed the Latest Robotstudio with an Test license.
I run now into an Problem opening the file.
20.06.2025 14:54:57
RobotStudio .NET exception: system creation failed due to
ABB.Robotics.RIM.InternalSystemException:
   Python Layer: (Trigger: UpdateSettings) Internal System Error.
   bei ABB.Robotics.RIM.HostDataProvider.UpdateSettings(ICollection`1 products, String ctrlName, String location)
   bei ABB.Robotics.RIM.VCController.UpdateSettings(Settings2 settings, Boolean IsCreateSystem)
Base exception: SystemCreationFailedException
   bei ABB.Robotics.RIM.RobInstallManager.CreateVirtualController2(ControllerSystem2 cSys, String controllerLocation, String productsInstallationParentPath)
   bei RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRW6.<>c__DisplayClass1_0.<CreateVirtualController>b__0()
   bei System.Threading.Tasks.Task.Execute()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
   bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   bei RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRpkBase.<CreateSystemFromBackupAsync>d__13.MoveNext()
   bei ABBInternal.StationManagement.PackAndGoService.<CreateSystem>d__17.MoveNext()
   bei ABBInternal.StationManagement.PackAndGoService.<UnpackAndWork>d__14.MoveNext()
anyone an Idea?
Its Windows 11 Pro
  • Hi Peter,
    If I recall correctly you need to have a specific IronPython version installed.
    The version of IronPython required by RIM is 2.7.4 and it can be downloaded from 'https://github.com/IronLanguages/main/releases/download/ipy-2.7.4/IronPython-2.7.4.msi'.
    Maxim Riabichev
    PC Software Support Engineer
  • PeterPan
    PeterPan
    edited July 2025
    Ok I installed the IronPython and restarted to PC
    Did try to open the pack and go but getting the same result.
    Not sure if the Actual RobotStudio have bigger Problems cause I tried to open an Older PackandGo file that I could open with Version 2023 and try open it with latest I get:
    RobotStudio .NET exception: Option "abb.robotics.robotware.robots.irb2600.12-1_65.typec" is not part of the added product manifest files features, check the feature name or dependency products
    If check in the ABB LIbrary the Robot is there.
    Or Maybe its an Windows 11 Problem cause As I tried creating the Conroller manualy from Backup I get:
    RobotStudio .NET exception: C0040403 : No response from controller.
    Netscan timeout
    Base exception: RobApiException
    Netscan timeout
  • Yeah, it sounds like there might be something on your PC that is preventing the controller from either be created, or started, or both.
    Check if you have some anti-virus blocking the RobotStudio processes such as InstallationManager.exe in the RS installation folder, and RobVC.exe in C:\Program Files (x86)\Common Files\ABB Industrial IT\Robotics IT\RobVCCommon
    Maxim Riabichev
