Robotstudio Crashing
During creating controller in RW6 Robotstudio just crash. I have latest version of robotstudio but it happens also on old versions. With RW7 there is no issue. Can someone help me with this issue ?
Thank You.
Here is error log:
----HEADER END----
----LOG BEGIN----
00:00:00|UIThreadWatchdog|Started
00:00:00.3299177|Exception|07b2f9c7-b569-47eb-bb03-028cc9fe9a4b|System.IO.FileNotFoundException|Silent
----EXCEPTION BEGIN----
Could not find file 'C:\ProgramData\ABB\RobotStudio\7.x\4c42e7d6d31b1905321646ae27ee6d636807c416\01234-01234-01234-01234-01234.cny'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
   at RobotStudio.API.Internal.FileServices.CopyFile(String sourceFileName, String destFileName, Boolean overwrite)
   at RobotStudio.API.Internal.FileServices.CopyDirectory(String src, String dst, Boolean overwrite, Boolean recursive, Func`2 filter)
   at RobotStudio.API.Internal.FileServices.CopyDirectory(String src, String dst, Boolean overwrite)
   at RobotStudio.API.Internal.LicenseValidatorInternal.<>c.<BackupStorage>b__8_1()
   at RobotStudio.API.Internal.LicenseValidatorInternal.WithStorageMutex(Action action, Int32 timeoutMs)
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at RobotStudio.API.Internal.ApiExtensionMethods.<Observe>d__25.MoveNext()
----EXCEPTION END----
00:00:00.9356077|User|SignedOut
00:00:01.4172763|AddinAdded|I/O Engineering|General
00:00:01.4182793|AddinAdded|Visual SafeMove 2|General
00:00:01.4192847|AddinAdded|MultiMove|General
00:00:55.3557366|AddinLoading|I/O Engineering
00:00:55.3597364|AddinLoaded|I/O Engineering
00:00:55.3597364|AddinLoading|Visual SafeMove 2
00:00:55.8002598|AddinLoaded|Visual SafeMove 2
00:00:55.9066049|GraphicsFeatureLevel|D3D_FEATURE_LEVEL_11_0
00:00:56.2534316|AddinLoading|MultiMove
00:00:56.2604243|AddinLoaded|MultiMove
00:00:56.2674251|BackstageVisibilityChanged|False
00:00:56.9391776|UIThreadWatchdog|Warning|2000 ms delay on UI thread
00:00:58.1853996|StationCreated
00:00:58.3834303|ActiveWindowChanged|GraphicWindow|NoId
00:00:58.9505810|UIThreadWatchdog|Warning|4000 ms delay on UI thread
  • Maxim Riabichev
    edited August 2025
    Hello there,
    These kinds of issues usually occur because PC's anti-virus is preventing RobotStudio processes from starting.
    Check if you are allowed to start InstallationManager.exe from the bin folder under RobotStudio installation path.
    In general, try to see if you can white-list RobotStudio in your anti-virus software.
    Maxim Riabichev
    PC Software Support Engineer
