How to remove old files from directory (Selected by date)
Hello evreybody,
I'd like to remove the fold files (Older than 1 year) I created with the following code :
            VAR string stFilePath:="Home:/BackupLogs/";
            VAR string stFileName;
            VAR iodev logfile;
            VAR string stPart;
            stFileName:=stFilePath+stDate+"_MyFile.csv";
            Open stFileName, logfile\Append;
            Write logfile,stTimeLogs;
            Close logfile;
How could I filter and remove the files containing the stPart in the name ?
            stPart := StrPart(stDate,1,4);
            RemoveFile(stFilePath+"/"+FileName);
Thanks for your help
Regards
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
HP ZBook Fury 16 G11
  • SomeTekk
    SomeTekk
    edited August 2025
    Is there a possibility of writing your files to an external device?
    It has been observed writing to a Windows PC and running a batch file, or PowerShell script, against the folder with the files has worked.
    Post edited by SomeTekk on
  • Hi SomeTekk,
    I have to try.
    I'll keep you inform, but I can't do it quickly.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • SomeTekk
    SomeTekk
    edited August 2025
    I am a bit fuzzy on exactly what options are necessary.
    The RAPID REFERENCE Manual was a great tool used to get the results I needed exported to an external destinaton.
    Here's an AI generated PowerShell script deleting old files and folders:
    # Set parameters
    $targetDir = "C:\Path\To\Your\Directory"
    $daysOld = 30
    # Calculate cutoff date
    $cutoffDate = (Get-Date).AddDays(-$daysOld)
    # Delete files older than the cutoff date
    Get-ChildItem -Path $targetDir -Recurse -File | Where-Object {
        $_.LastWriteTime -lt $cutoffDate
    } | ForEach-Object {
        try {
            Remove-Item $_.FullName -Force
            Write-Host "Deleted file: $($_.FullName)"
        } catch {
            Write-Host "Failed to delete file: $($_.FullName) - $_"
    # Delete empty directories
    Get-ChildItem -Path $targetDir -Recurse -Directory | Sort-Object -Property FullName -Descending | ForEach-Object {
        if (-not (Get-ChildItem $_.FullName -Recurse)) {
            try {
                Write-Host "Deleted empty directory: $($_.FullName)"
            } catch {
                Write-Host "Failed to delete directory: $($_.FullName) - $_"
    Best of luck!
