S4 controller
Merce
I’m on a s4 controller (hate)
How would this be done?
I’ve also noticed on this controller the program that’s been set up has a rob target for each programmed step is this normal for this controller?
You don't really have to use a MoveC, you could program one point in the corner and use the zone size to get it rounded the way you want it. Hint: you might have to over teach the corner position.Lee Justice0
