[Wish] Synchronize path to station
Tompanhuhu
in UpFeed
When I right-click a path, I get the option to "Synchronize to RAPID...".
I would like the option to Synchronize to Station and get the path pre-selected in the popup dialog.
☑️2024 - RobotStudio® User Group
Hi...I don't know if this option exists! Why would it be necessary?In the Simulation tab, when you create a path using the drawing tools don't have the Synchronize To RAPID option, this is missing. Therefore, this option is a way to synchronize without having to navigate between tabs. However, if you created a path using RAPID, you can synchronize it using the Synchronize To Station shortcut on the toolbar.1
Well I got a system with over 100 procs, but only 10 contains movements.
So I want to write rapid (change offsets and so on..) and then update the station with the new values.
But I don't want to search for the proc in a list with over 100 procs when I know I only want to sync one path.
So it would be perfect to have the same function as Synchronize to RAPID... but reversed.Systemintegrator - Web / C# / Rapid / Robotstudio
☑️2024 - RobotStudio® User Group2 -
Second this. Either that, or have the path list filterable by module?0
bumpSystemintegrator - Web / C# / Rapid / Robotstudio
Something like this would be useful for me to.
My personal preference is to always "clean up" my station after syncing the proc back to Rapid, and I usually only work with one proc at a time.
I delete the path and right click on T_ROB1 and select "Remove unused targets". Then I delete the work objects.
For me a function to "Remove all targets, tools, wobjs and paths" would also be useful.-----------------
David
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
