IRT710 lubrification
We have a IRT710 axis with automatic lubrication (MEMOLUB EPS pump controlled by the robot via a digital output).
ABB recommended activating the pump every 6 days in the product manual.
I would like to activate the pump depending on the distance traveled by the axis. Is there a way in RAPID to read the distance traveled by the IRT710, e.g., from the SIS data, like the gearbox hours of the 710?
Thank You
Daniel
Thank You
Daniel
Yes. There is a function, GetAxisDistance, that will return a Dnum of the distance traveled in meters for a linear track or degrees for a rotational axis.Lee Justice0
