FlexPendant Problems caused by RW
WGQmomo
I'm using RS5.07.01.
And I made a test:I creat 4 virtual system (which only contain a IRB6600)based on 4 RobWare: 5.07.5002/5.07.4002/5.07.0153/5.07.1023
The result is only in the systems based on 0153 and 1023 I could open FlexPendant. While based on 4002 and 5002, it pops up an error window.
Can you tell me why?
It sounds like its not forward compatible with newer versions of RW, i.e. 5.07.04/05. You would probably need a newer version of RS.Russell Drown0
Yes, I agree with you. So I update RS to 5.08.01
Still I build a new system with a naked IRB 6600.
When I open virtual flexpendant, an error window pops up and I cannot find "program editor" in the flexpendant.
Why~
