Backup Directory for Omnicore VC
I have a system input tied to a digital input to take a backup. I can only get the backup to work when the directory specified in the system input is BACKUP. I want to put it in the HOME directory, but no matter what I do, I cannot get that to work.
  • DenisFR
    DenisFR ✭✭✭
    If you put your Backup into Home, your next backup will contain it, and so on...
  • Makes sense. I can't seem to take a backup to any other location besides the BACKUP directory though. I can't specify a path to my own directory at the same level as BACKUP. On IRC5s, the path "SYSTEM:custom-directory" was valid for backups taken via system input, but that doesn't seem to work on omnicore. At least not for virtual controllers.
  • jbultman
    jbultman
    edited December 4
    I'm forced to put my rapid modules in the HOME directory because I can't seem to access any directories at the SYSTEM level besides HOME, BACKUP, and maybe TEMP.
