Robot Studio Online 5.08
I have recently upgraded to Robot Studio Online revision 5.08 and I have noticed a couple of quirks. Not sure if it is just my laptop or RSO. My laptop is running Windows 2000 by the way.
While trying to edit configuration parameters such as:
TOPIC:MOTION:ROBOT or TOPIC:MOTION:MECHANICAL UNIT
when I try to "right click" to EDIT parameters I do not get another window allowing me to edit parameters or apply changes. All I can do is really just view the parameters. I am forced to make changes through a text editor to the MOC.cfg, EIO.cfg, etc. Has anyone experienced the same problem?
ACB
A few questions:
What is the RSO version number listed in the lower LH corner of the Help>About... dialog?
What is the RW version of the robot you are trying to connect to?
Is it a physical system or virtual?
Where exactly are you right-clicking?
Here is a description of what should happen when you interact with Motion>Robot:
If you right-click "Robot" in the "Type Name" column of the Motion tab, you should see a context menu with the text "Add Robot...". This menu will be disabled if you do not have write-access or enabled if you do have write-access to the controller.
If you right-click a value of type Robot (anything to the left of the Type Name column), for instance ROB_1, you should see a context menu with the following choices: Add Robot..., Copy robot(s)..., Delete Robots(s)..., and Edit Robot(s)....All of these except Edit Robot(s) will be disabled if you don't have write access.
If you then select Edit Robot(s)..., a Parameter Edit dialog will be displayed, but all entries will be disabled unless you have write access to the controller.
Are you seeing something other than this behavior?
RussD2007-3-14 3:17:53Russell Drown0 -
Hello RussD, and thanks for the reply. I am still having trouble with RSO and yes the behavior is like you described, but I don't get a window that pops up allowing me to actually edit parameters including when I have write access.
RSO version = 5.8.2007.0
ROBOTWARE_5.08.2007 RobotWare 5.08.2007.02
This is a physical system.
Thanks,
ACB0 -
There was a problem with my laptop. It works now.
Thanks,
ACB
Thanks,
ACB0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
