Get Controller ID
oscar_f
Hello I'd like to get the Controller ID on which my application is running.
Is it possible?
How?
BR
OScar
BR
Oscar Ferrrato
Oscar Ferrrato
PS: I'm working on a FlexPendant Appl. RAB 5.08BR
Oscar Ferrrato0 -
What does controller.name return? Is it system name or controller ID?Russell Drown0
Hello
Is it the controller IP-adress that you want to retrieve? Currently there is no such Controller property in the FP SDK. It will be included in future releases (5.10).The controller.name is the name given the robot controller by the end-user. You see it when you do Add controller to your Robot View in Robot Studio Online. The end user can change the name by right-clicking the Controller node in the Robot View point att Properties and select Rename. This name is independent of the system or sys-pack that is currently running. Several controllers may have the same name.
Ingela Brorsson
ABB Robotics, Sweden0
