option for mechanical process?
hello everyone,
I have a 6600 robot to do mechanical process. now the problem is the external force which from the TCP(reamer) is changed frequently while processing,then the wrist have a little jumpness. so robot can't reach it's issued accuracy 0.1mm.
I tryed to define a loaddata to resist this jumpness,but still can't reach a good effect.
does anyone know whether there is a option of IRC5 can slove this problem.
Thanks a lot!
Peter
did anyone know the option: force control machining can do it?Peter0
New Option in RW 5.09
Force Control, have seen a demo yesterday.
Should do the trick
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
