problem with synchronization
dear all,
i've a problem.
1. what i do:
1) copy station and system file from other PC
or change the direcrtory of system on my PC
2) open station and relocate the system file
2. problem:
everything's ok
but can't synchronize path to vc!
output window shows:Synchronization to VC completed with errors. Please double click to view details. details is : [Fatal Error] Sync aborted
why this happens? anyone can help me? TKS.
Hi davidseven,
A system will not work correctly if you change its location and warm start it. You need to cold start the system in the new location, and then restore a backup. I recommend you use Pack & Go to create a package that contains the station, system and backup.
regards,
Johannes
Johannes Weiman
hi Jonannes,
thank you for quick reply.
Pack & Go can solve the problem.
but I wanna know if there are other solutions when I copy a simulation to another PC? Tks.
davidseven.
hi
this is the way i have done a copy from one PC to another
first i copy the mediapool from PC to PC
Then i save the original station on a networkdrive, and then open the station from the other PC where i have copied the mediapool ,and this works perfectly.
I havent had any problems doing it this way
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0
- 304 PowerPacs
- 355 IRC5
- 850 RAPID Programming
- 26 AppStudio
