Error when MoveabsJ
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
Can you move along the path if you add a Conj_Off instruction at the beginning of the path? There seems to be something wrong with the configurations stored in the move instructions. The robot cannot reach the targets with requested configuration.
Kind Regards
Fredrik38169,7023263889Fredrik Syr?n
Program Manager
ABB Automation Technologies0 -
Hi Fredrik,
I don't think that's the cause of the error. First of all because MoveAbsJ targets don't have an axis-configuration (for axis 1 through 6, the target just stores the rotation of each axis), So there's no need to insert the ConfJ_Off instruction. A second would be that even if the the robot can't move along the path, that wouldn't result in a crash.
Now for some info for yourself. The way you create targets in RS determens how the configuration is stored. If you were to create a path from a curve, no configuration is added to the targets (0,0,0,0) and the use of the ConfJ/L instruction is required to make the robot move along the path. Or, like i do, you manually add the correct config afterwards. (It would be very nifty though if RS could automatically determen a config while creating a path from curve, based on the active TCP..)
If you create targets one by one on the TCP (the lil' "teach target"-button), a config IS automaticallly added. But that means you must be a good Jogger in RS to get all targets right..
<@Logan> I spent a minute looking at my own code by accident.
<Beeth> And your point is?
<@Logan> I was thinking "What the hell is this guy doing?"0 -
The error only comes when i use move along path. If i use execute procure i programbrowser it runs the routine without problems
So there can,t be anything with the path(It also runs on the real robot.
Its only rs that has a problem. not the real robot
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
[QUOTE=Fredrik]
Hi Klaus,
Can
Kind Regards
Best regards Klaus
Best Regards
Klaus Soenderhegn
Hmm strange.. I might have a suggestion. Well, it's not something to find the exact cause, but it might be a solution.
Does RS still crash if you:
1. delete all targets and paths from the station and then
2. resync your program from the VC back to the station(I've had some problems in the past which were caused by differences in the Workobjects from the station and the VC.)
Melk38177,5775462963<@Logan> I spent a minute looking at my own code by accident.
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
