Fatal Error defining Mechanism Poses
Hi.
I created my own mechanism on RS 5.08, but I had a Fatal Error message while I was defining the mechanism poses.
I've tried to generate a new mechanism, I've got an example from the forum and the same problem again.
Thanks.
Robotics - BIW Brasil
Me too. Tried to do a device type mechanism. all the nodes were green, but when i compiled it, the program crashed!!
Are you running Win2000?
Creating poses will not be possible when running Win2000 due to a limitation, it should however work fine on WinXP. Note that RS5.08 is the final release of RS that will support Win2000.
__________________
Anders Jahnberg
ABB Automation TechnologiesBest regards,
Anders Jahnberg
Hello Anders.
Yes, I'm still running Win 2K... It takes me a lot of time to upgrade for Win XP...
As I need to run RS, so I won't have other way but upgrading to Win XP...
I will try to generate this mechanism on a computer running Win XP...
Thanks.
Thiago Ramos Falcao.
Body-in-White (BIW) - ABB Robotics Brazil
Thiago Ramos Falcao
Robotics - BIW Brasil0
- 398 UpFeed
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 327 IRC5
- 65 OmniCore
- 821 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
