Assembly system
Say I want to build a machine using lots of component parts.
The robot will pick the parts from fixture positions, and assemble them.
When i have finished the simulation, is there a quick way of putting all the parts back to their starting positions, or do I have to do it by hand?
  • Klaus
    Klaus ✭✭
    Hei.
    You can use the undo after simulation and all your parts will return to the posision before simulation.
    Best regards
    Klaus
    ProInvent Denmark
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
