Training Exercise 6.4.1( RS5.08.01)
The training exercise 6.4.1 in the RS5.08 training manual, requires the creation of multimove synchronized paths using 2 X IRB1410's around a pipe rotated by positioner.
Allthough the paths are created the welding guns pass through the centre pipe.
I have tried to apply constraints to the joints and TCP but the problem still exists. I have moved the start positions as suggested in exercise and even the robot base frames.
It would be good if you could specify that the gun/ robot cant pass through the pipe... a bit like the flexi pipe addin in RS 3.2
Has anyone got this exercise to work correctly? if so how?
Got it working, but only when welding guns are under the pipe part. Changing the start position seems to be very-very sensitive to outcome. trial and error i guess.
