TriggIO and Fixed Position Events
Hi, I'm using a trigger instruction to reset an output signal while moving. However when compiling it says :
"Error 161 Option is missing : The instruction TriggIO requires the option Fixed Position Events". Which I can't find in the manual!
My code looks like this:
VAR triggdata trigger_release;
and in proc main() :
TriggIO trigger_release, 0 Start DOp:=zonen_bokad_DO,0;
TriggJ target_b,v100,target_release,z10,AW_GunWObj:=wobj0; &n bsp;
What does this mean and how do I solve it?
  • Hi
    To be able to use Trigg instructions you need the option "Fixed Position Events". For a virtual controller that's easy just use System Builder and create a system with the options you need. For a real controller you need to order the  robot with that option.
    Per Svensson
    Consat Engineering
  • Ok, thank you very much. Will try that immediately. Can i change the system properties of my virtual controller now, or do I need to create a new system and start from scratch and add the program modules to that system?
  • You can modify an existing system but you need to restart it(I Start in RS) which will wipe out your modules so save them first.
    Per Svensson
    Consat Engineering
  • How do I add these parameters, as all I can see in the system configuration dialog is Add parameters to the system, which requires .cfg files to be added..?
  • Start system builder from menu controller and select your system and press modify and then press next until you get to the "Modify Options" dialog and check option 609-1.
    Per Svensson
    Consat Engineering
  • Thanks a lot, Per!
