Connect 2 IRC5 controlers DeviceNet
I need know if its possible connect 2 controlers IRC5 with DeviceNet, I need change values in a controler IRC5 and this values they are send by another controler IRC5, The Adress deviceNet of the controlers are the same by default, it is possible change the Adress of a DeviceNet controler IRC5?
Thanks,
Joao Fidalgo
  • Yes it is possible, see the attached document for more information.
    2007-08-02_233806_devicenet.zip
    You change the master address of a DNET board in RSO under IO>Bus>DeviceNetX>DeviceNet Master Address.
    RussD2007-8-2 23:39:33
    Russell Drown
  • Hi RussD,
    Thanks for your help!
    Tomorow I will make that experience!
    Joao Fidalgo
  • Hi RussD,
    Now it works!
    Thanks!
    Joao Fidalgo
