RS Online Fails to Start
When I try to start RS Online, I get the following error:
Could not load file or assembly 'ABB.Robotics.RobotStudio.Online.Interop.AxSwcAppComponentLi b, Version=1.0.0.0, Culture=neutral, PublicKeyToke...
RobotStudioOnline.AppWindows
On clicking OK, RS Online crashes. This happens when I try to open RS Online independently and also through RobotStudio.
I am using RS Online 5.09.0166 and RS 5.09.2188. I also have RAB 5.09 installed on the same machine.
Does anybody know why RS Online will not start up?
Thanks in advance,
Neil
  • Hi
    Had the same problem half a year ago and did an uninstall of RSO and then installed it again and it was ok.
    The file is probably missing in the assembly cache.
    Per Svensson
    Consat Engineering
  • Re-install of RSO seems to have corrected the problem.
    Thanks,
    Neil
