strings
Currently I am trying to make the flex pendant tell the operator what tools are used for a program and what location they are in, I am trying to use UIMsgBox and I am calling strings up to tell the operator where the tools are meant to be, the problem I run into is we have about 4 tools, and they could be in 4 different locations for each program, basically what I was hoping to do was call a string within a string i.e. create the string "tool holder 1=" and then create another string "1/4 in. Router bit" or "4in Saw Blade"
So basically what I would want to accomplish is for UIMsgBox to combine those string on a single line, is this possible?
dh_custompak2010-05-30 04:33:35
Hello Dustin,
You need to use the "+" to connect strings together.
PERS string stToolpos1 := " 1/4 in Router bit";
UIMsgBox "Tool holder 1="+ stToolpos1;
This will display on the FlexPendant as
Tool holder 1= 1/4 in Router bit
When doing this through the FlexPendant use the Expression button to call up the screen to add the + sign.
BR
Jim Proulx
Attached is an example.
2007-10-31_153312_UIMesgDemo.zip
Thanks Jim, that will make things a lot more organized
Dustin0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
