About RelTool
Hi everyone
i need your help,the robot type is IRB 6400 and the OS is S4C 3.0-4.
i want the robot to rotate 180 degree around its Z-axis.so i program it like below:
MoveL RelTool (p1, 0, 0, 0 Rx:=0Ry:=0Rz:= 180), v100, fine, tool1;
but when you run it,an error message will appear on the teachpendant,which says 50080:Position not compatible.
Position cannot be reached with the
given robot configuration,if you change180 degree to less than 135 degree,it can be run
what's the reason
thanks a lot!
You need to turn of configuration, because the teached configuration on axis6 is different between p1 and rotated p1.And you do that like this
ConfLOff;
Per Svensson
Consat Engineering0 -
The reason is that the robot don't now witch way to go to archive the configuration, so it is limit to reorient more than 90 degrees to keep the robot on a liner path.<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
You can turn off the configuration check whit ConfLoff ; and on ConfLon;
divide the reorientation in more points...
MoveL RelTool (p1, 0, 0, 0 Rx:=0Ry:=0Rz:= 90), v100, fine, tool1;
!! ok if fine is use before !!
P2:=CrobT();
MoveL RelTool (p2, 0, 0, 0 Rx:=0Ry:=0Rz:= 90), v100, fine, tool1;
or use MoveJ
MoveJ RelTool (p2, 0, 0, 0 Rx:=0Ry:=0Rz:= 90), v100, fine, tool1;
or
p2::=CalcJointT(RelTool (p1, 0, 0, 0 Rx:=0Ry:=0Rz:= 180),tool1);
MoveABSJ p2, v100, fine, tool1;
or
P2:=CalcJointT(RelTool (p1, 0, 0, 0 Rx:=0Ry:=0Rz:= 180),tool1);
p1:=CalcRobT(p2,tool1);
MoveL p1, v100, fine, tool1; !more than 90 deggres
or I think you <?:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />kan change the value of the recorded configuration to be betwen the 2 points. coresponding in your case to real position RelTool (p1, 0, 0, 0 Rx:=0Ry:=0Rz:= 90)
like
p1.confdata.cf1:=??
p1.confdata.cf4:=??
p1.confdata.cf6:=??
p1.confdata.cfx:=??
PS. if the reorientation is more than 90 confdata will change by +/- 1MoveL instrucktion will give alarm if change by +/- 2 equals more than 180 degrees. if not ConfLoff ..!
or if confdata is set to [0,0,0,0] no configdata is used
IS THIS CORRECT ??
Use the instruction confL/OFF0
Thank you,PerSvensson,vulpes_h and Semircn
all your solutions can solve this problem
I really appreciate your help
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
