Problem with IRB4400 S4C+
Hello,<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I'm having a problem with a IRB4400 2000 s4c+ controller.
It is been for years now that modules are added to a existing program. Last time after changing a program (adding a module) by a network connection, and then loading the program into the active memory, I got this message:
MCO:PGMLNK.C 3451
20311 Enable Open
10014 System error Status
I had to cut off the power, so he has done a P start, en had to do a restore of the previous backup.
I thought that we were running out of const robtargets, so I deleted the ones that were not used. After trying again, it worked, but when you reload it once more, I get this error again.
Can somebody help me with this problem.
Q
I'm having a problem with a IRB1400.
error 20311
status active when enable from I/O computer open
20311 enable 1 open
10014 system failure state
20076 not allowed command
10005 program stopped
Can somebody help me with this problem0 -
Please add a Backup so i can see your configuration .... (add Log file)<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Enable 1 open, can bee open by a lot of reson.
"Panel board" and the "conector board" are runing a internal can bus, from the I/O-computer.
I think "Enable 1" is runing through all these components..
Check electrical drawings can give a hint!
Check errors on console port .. (9600 boud) givs a hint on which part is failing in start upp mode.. (if you have lookt at the print out before)
I think you can se status on "sys inputs" by typing EIO_show or eio_show in the terminal.
A hint about "show" comand in a terminal window write -> lkup "show"
and a list on show instruction will appear
I forgot the KERNEL - C-code can also be a resson or a very hevy load on the I/O-buss if Poll rate is to low.
vulpes_h2007-11-5 23:13:190 -
Hello...
When did the error occur? Upgrade? runing program ? Reboting,restart ? Loading a backup? or configuration of multitasking? event_rutins?<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />Will a i Start help ?
a I-start will reboot a system to default configuration. (Program and motor-configuration I/O-configuration) will be reset to default...
go to
1. service ,
2. restart
3. then press 1,4,7
and I-start will be present!
If you still have problem after i-start, then it can be the robotware "c-code" fore the robot..
If system ok ... load a working backup
else..
try to do a C-start
1. service ,
2. restart
3. then press 1,3,4,6,7,9 C-start
C-start will empty the robotware and the "system" include "system/Backup" folder copy backup from folder to PC by FTP.
to save rapid code and configuration.... for loading later!
Now you have to load a complete new "system" from "RobInstall" systembuilder for s4c+...
If NOK now then it is a hardware problem...
Thank you very much for advice.
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
